I'm considering using the PSOC-5 in my design (Industrial/Military standards required) for the following task :
- Power sequncing (up/down) and voltage monitoring (using the internal ADC-s) of several DC-DC/LDO-s.
- Current / Temperature monitoring (using the internal ADC-s) of a few power rails / PCB hot spots (Using external Current/Temperature to Voltage Devices).
- Reset (input discrete) signal management - time debouncer, performing power sequencing when reset asserted.
- Events Log record (Resets, voltage regulations vs time, etc.) over the internal EEPROM.
- Real-Time transfer of all measurements mentioned above, over I2C/SPI/UART(to extenal device).
- Configuration (may be one time) of several devices over I2C/SPI.
To accomplish these tasks, can you point on pros and cons of this device, in comparison with other vendor CPLD-s, specifically Intel's MAX-10 (Try to be objective)?
What is the Longevity of the PSOC-5 (Which part has the longest life cycle/ farthest EOL estimation?)
Max
PSoC 5LP
PSoC5 and MAX-10 are different class of devices, how they can be compared? PSoC5 can accomplish all of the above in a breeze, but I would be concerned by the pricing and long-term availability.
/odissey1
