adpac_1560036
Level 4
Level 4
Hi im designing an application to use capsense buttons with psoc5 cy8ckit-059. i have fabricated a simple capsense board with five 12mm dia copper footprints each connected with a 1 mega ohm resistor. i think this should be ideal for the low end design im trying as i read somewhere. planning to use port 1 pins 2,4,5,6,7 for my 5 capsense buttons. im also using the onboard cmod capacitor. please suggest me if what im doing is correct and also the way in which i have to configure my capsense module in psoc creator. thank you.
rola_264706
Level 8
Level 8
Here is the design guides I am sure you will be able to find the information you need in them.
Thank you bob. What is
your suggestion to design a capsense board using single layer pcb?
gare_4364206
Please some help me need a product recommendation from this site- gadget reviews
