PSoC 3
Bob
You should take a look at the programming specifications of PSoC3 for the hardware connections.
Link:
http://www.cypress.com/?rID=44327
You actually don't need any external resistors on the lines. Also take care that when your Vddio1 is 5V, your power of operation of miniprog should be 5V.
Take a look at the spec section 1.2.2.
Garima
The BMP that was attached definitely answered my question about isolated supplies. It is not possible. However that doesn't fix my problem, because I have had their references tied together while trying all this troubleshooting. I tried running out of the 5 pin connector on the miniprog3 but that doesn't change anything. Furthermore, after exploring those options, the miniprogrammer software does not list my device under any protocol but JTAG. The best I can get is a list of unknown devices 0xffffffff. It can't ever seem to acquire the device in PSOC creator or miniprogrammer.
Does anyone know if the device uses an internal oscillator or the external crystal the first time it is ready to be programmed?
Of course, use internal oscillator when the programming is started.
If not so, When the Xtal was broken, programming never can start.
The example schematic at end of programming specification does not show
an external clock.
Regards, Dana.
