hi, I need programming PSoC1 with PPCLI.exe , and I have one one Miniprog3 on hand .
and I would like use runfile to do programming.
but at begin when execute "Acquire" , will have error (
Can not Acquire Device! Please verify the device connection to the Programmer
Acquire returned 80030001
for this , I am sure the device has been connect to the programmer.
but if I execute the command step by step as follow:
>OpenPort MiniProg3/1707CA000523 "C:/Program Files (x86)/Cypress/Programmer"
0 OK
>SetAcquireMode "Power"
0 OK
>Acquire
0 OK
after "Acquire" OK,  then execute "runfile" command , it is no problem.
but if I disconnect the Miniprog3 from the PC , the error for "Acquire" occur again
can you tell me how to solove this problem?
Follow is the process for PPCLI:
Microsoft Windows [版本 10.0.14393]
(c) 2016 Microsoft Corporation。保留所有权利。
C:\Users\Administrator>cd\
C:\>cd C:\Program Files (x86)\Cypress\Programmer
C:\Program Files (x86)\Cypress\Programmer>ppcli
>runfile "c:\\12.txt"
0 OK
HEX_ReadFile "c:\\CSR_E.hex"
<0x00004000
0 OK
SetAcquireMode “Power”
0 OK
SetProtocol 2
0 OK
SetPowerVoltage 5.0
0 OK
Acquire
E
80030001 OK
Calibrate
0 OK
EraseAll
<0x00000000
0 OK
Program
0 OK
Verify
E
Found 0 PROTECTED blocks; 256 block(s) had errors in the remaining 256 UN-PROTECTED blocks; Device checksum 0x0000, HEX file checksum 0x8785 byte 0x3fc0
Verify returned 8003001a
8003001a OK
Protect
0 OK
VerifyProtect
E
Verification of "Protect Area" has FAILED!
VerifyProtect returned 80004005
80004005 OK
CheckSum 0
<0x00000000
0 OK
HEX_ReadChecksum
<0x8785
0 OK
ReleaseChip
0 OK
ClosePort
0 OK
0 OK
0 OK
0 OK
>Acquire
0 OK
it seems find the root cause:
in the file , need add PowerOn command.
then the programming is no issue.
