As far as I know, most devices fail when they are switched On!
I would suggest to read-out the flash and compare it with the desired hex. When you have debugging capabilities integrated to your board you even may inspect the memory contents.
Bob
Suspect as always is tranients on I/O pins that inject charge into the
substrate, and potentially corrupt FLASH cells. Or transients on Vdd
that exceed gate ox breakdown. Best way of detecting a condition like
this is a DSO set to trigger on something like this -
Vss - .7V > Vtrig > Vdd + .7V
and look at key interface pins talking to loads than can generate
transients, like a relay, a MOSFET driving a relay (transient feedback
thru Cgd). Set up jig to cycle power, and enable DSO on signal that
triggers power up and down.
This is vary tedious to find, patience is a virtue.
Also in general power supply sequencing, make sure PSOC comes up
before any I/O loads do. If you cannot guarentee that make sure all pins
clamped by zener arrays, avaialable from On Semi, Vishay, Fairchild to
name a few.
Regards, Dana.
How do you find the PC corrupted?
Would there be some cases where your EEPROM value is out of your expected range and your program perform not as you expected?
