Hello.
I need to know the output impedance of OpAmp. I don´t find this impedance in datasheet component.
Thanks for the reply.
PSoC 5LP
No exact value specified, probably due to the wide supply range. Datasheet tells Iout max. is 10mA @4.5V
Bob
Bob
Thank you Bob
Do you know "SC3_vin"?
Cris
Do you know "SC3_vin"? Yes, he comes in every Tuesday for some talk and a drink ;-))
Sorry, but a little hint where you found it could be helpful to answer that question.
Bob
Hi Cris,
You can find SC3 pin in Switched Capacitor / Continuous Time (SC/CT) analog block of PSoC devices.You can refer the following link for better knowledge .
