12:13 PM
May 31, 2012
12:13 PM
I'm trying to multiplex two analog signals inside the PSOC 5 to an output pin. All implementations of the multiplexer say the only valid connection to the input is a GPIO signal. Is there any way to accomplish what I am trying to do? I've thought of running the signals out of the chip and then back in, but the board is already laid out.
Labels
PSoC 5LP
12:57 PM
May 31, 2012
12:57 PM
On the very first page of the datasheet is noted that the inputs for the AMuxHw MUST be GPIO-pins.
I'm afraid, you'll have to use an AMux or an AMuxSeq which may not be controlled with a signal but must be switched by CPU.
When the frequency is not too high I would suggest to use an interrupt and an Isr-component to switch inputs.
Bob
