I would really like opinions on this question:
I current produce a Amateur Radio device (transceiver) that uses the PSoC 3 48 pin SSOP (CY8C3246PVI-147). Which newer device is most compatible with the PSoC 3 from both a hardware and software perspectives? I know that no newer chip has the 48 pin SSOP foot print and I will need bite the bullet on that one. Which newer chip allow me to move my application to it with the minium changes required? I have had the opportunity to work with a number MCUs over the past couple of years, and still find that Cypress has the absolute best hardware and IDE platform available. The only down side is from a hobbyist perspective, in that I will need to change the way I present kits. Moving forward I will need to provide kits that have the PSoC pre-installed.
Ron
PSoC 3
Did you try (on a copy of your project) to select a PSoC5 of your choice and just compile the project? Most components and code will run & compile without any changes.
Bob
