Hi everyone,
I am struggling using the Mixer correctly.
My goal is to mix a sin Wave (Fin =À low freq 10Hz) with carrier frequency 20kHz (LO internal) and get an output amplitude of around 2Vpp.
I have with me an old freesoc mini with a 5LP CY8C5868LTI-LP039 (VDD=3.3V).
I used a WaveDAC, set my range to 4.080V, put an offset at 1.024V to be able to get something around 2Vpp
The mixer is configured as below: Multiply up, internal LO 20Khz
I would have thought to get something like this:
But I can't get anything nice.
First of all, my sinus has a lot of ripple at the frequency of the carrier.
Then my output is centered at 1.024V but the amplitude is not constant:
I could not find anything about the mixer that is not out of date like this https://www.cypress.com/documentation/code-examples/ce95337-analog-signal-mixer-psoc-35lp
Do you have any idea where the problem could be? When the mixer multiply by +1 or -1 it need to have the Vref plus also the top Vmax and Vmin of the Fin no?
Thank you all.
PSoC 5LP
I could recreate the issue at my end. I resolved the issue by buffering the WaveDAC output as shown below. Resultant waveforms are also provided below.
Circuit modification:
Resultant Waveform after modification:
Vasanth
Vasanth
Vasanth,
Isn't
the same this as:
Len
Hi Len,
Yes, both are the same. We can use VDAC 0 -4.080 (Buffered) in the range selection to enable buffering internal to the component.
Vasanth
