I am trying to test out programming the PSoC5LP dev kit using SWD over the 5 pin interface using the MiniProg3 kit. The PSoC Dev kit board has a 10 pin header for debug and programming, I have been trying to wire up an interface that will allow the programmers 5 pin female molex conector to connect via ribbon cable to the 10 pin port on the dev kit, but my last attempt didn't quite cut the mustard in build quality.
I have been able to sucessfully program a board using the 10 pin interface, but for my use, it's very important to reduce pin count and board size so in application we must use the 5 pin interface, and before we roll out our own boards, I do want to have tested this functionality.
Does anyone have any sugestions for what I am trying to test out, perhaps someone has already done this, probaly a much easier way than what I have been doing ?
Thanks!
PSoC 5LP
