hata_3396041
Level 4
Level 4
First solution authored First like received 50 questions asked
Hello
I have additional questions about this thread.
It would be very helpful if you could answer by 5/10.
There was a reply that you should develop using the latest version, but how should I migrate?
An error occurs when trying to open a .soc file created with Ver4.4 with Ver5.4.
Can it be solved on the assumption that the file created with Ver4.4 is used?
Best Regards
Hayto
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
You can open the PSoC Designer 4.4 project using PSoC Designer 5.0, and rebuild the same. After successfully rebuilding the project using PSoC Designer 5.0, you can migrate the project to PSoC Designer 5.4, and rebuild.
Sampath Selvaraj
SampathS_11
Sampath Selvaraj
