hata_3396041
Level 4
Level 4
First solution authored First like received 50 questions asked
Hello
Please tell me about USB UART Driver.
I am using Windows 7 32bit.
Install "Microsoft Certified USB UART Driver"
I tried connecting the PSoC module and trying to update the driver from the device manager,an error is displayed, "Driver not found."
Is Windows 7 32 bits not supported?
There was no problem in running on Windows 7 64bit.
RyanZhao
750 replies posted 100 sign-ins 100 likes received
Tanaka-san,
According to this KBA, it can support both Windows 7: 32- and 64-bit versions.
Operating Systems Supported by USB-Serial Controllers - KBA85910
Which kit are uusing? May try installing its driver manually.
RyanZhao
Tanaka-san,
Ryan-san,
Thank you for your reply.
A self-made module using the device of CY8C5888LT-LP097 is used.
It is strange because it is displayed in the device manager in the 64-bit version.
Tanaka
Tanaka-san,
I don't have a 32-bit system...may not try it at my side.
Have you tried installing the driver manually?
Ryan
Ryan-san,
Yes,I tried installing the manually.
Use a supported version as this is not a critical issue.
Thank you for the response.
Tanaka
Tanaka-san,
For PSoC 5 LP USB UART application, the code example called "USBFS_UART" in PSoC Creator may help to understand how to configure the driver better.
Ryan
