Hello, I want to read a PWM signal output from a sensor. I am feeding this continuous PWM signal to P1_5. I tried many examples from here. But I always have a false trigger on the pin, even if I remove the sensor from the pin. Can you please guide me how to measure PWM signal properly?
Roy_Liu
1000 replies posted 500 solutions authored 5 questions asked
The content in the links below could be helpful:
PWM measurement
Frequency Measurement
Time Period Measurement
Roy Liu
LinglingG_46
10 questions asked 5 questions asked 250 sign-ins
Can you describe the details about the false trigger?
What chip do you use?
Have you try to use the Oscilloscope to test the signal?
I am using CY8CKIT with CY8C5888LTI-LP097 microcontroller on it. I tried the oscilloscope too. A signal is perfect PWM changing duty cycle according to physical change. I just want to read duty cycle and frequency of a signal. It would be great if you can provide me any code for this. I tried with PWM, counter and UART to read out values. PWM_MEAS.PNGMeas_2.PNG
Roy_Liu
PWM measurement
Roy Liu
