PSoC™ 5, 3 & 1
Bob_Marlowe
Level 10
50 questions asked 10 questions asked 1000 solutions authored
Level 10
Hi Community,
here is something working that you may use freely.
A matrix keyboard (4 x 3) debounced and buffered, adaptable to your needs.
Have fun!
Bob
Hi Bob Marlowe,
Thanks a lot sharing your project here.
EdUc_284901
Level 4
50 replies posted 25 replies posted 10 replies posted
Level 4
Thank you Bob for sharing! I'm still looking for a good tutorial on psoc3/5lp. I still can't get it going yet on, I'm stuck with pic still.
Bob_Marlowe
Level 10
Level 10
"THE" main difference between pic and PSoC is: PSoC can do it analog! Be it to connect a photo-diode, amplifying and conditioning an input-signal or controlling an external analog device you usually do not need any external chips.
The way how to specify your needs by entering usermodules on a sheet and wiring all together is a great leap into the right direction, even I can do that and I am not an educatet electronic engineer.
So when you have got a developement kit go through the examples provided and try to understand them. Then pick (not pic) your own challenge, define your project and start to make it real step by step...
Happy coding
Bob
ETRO_SSN583
Level 9
5 likes given 1000 replies posted 750 replies posted
Level 9
There are a series of videos, start with "PSOC 3 and PSOC 5" 101,
then do 102/3/4.
www.cypress.com/
Regards, Dana.
EdUc_284901
Level 4
Level 4
Thank you all!
Regards from Buenos Aires, Argentina
Edgardo Daniel Ucha
Bob,
I can't seem to get Windows to unzip the file you posted. Any chance I could get at the unzipped code or an alternate file?
Thanks, Darin
Bob_Marlowe
Level 10
Level 10
Welcome in the forum, Darin!
I just downloaded the archive and successfully opened it, so there must be something wrong with your environment. I used
win7 and firefox.
Bob
Okay, thank you.  Does it include code to handle multiple simultaneous keypresses? I'm wanting to create a MIDI encoder for music keyboards.
"Unexpected end of archive" using Windows Explorer, WinZip and WinRar. Guess it just weren't meant to be...
ETRO_SSN583
Level 9
Level 9
I downloaded, extracted, re-zipped, try this one.
Regards, Dana.
Worked like a charm - thank you, Dana!
ETRO_SSN583
Level 9
Level 9
Check it, I do not think it is coded for multiple keypress. Bob can comment on that.
Regards, Dana.
Hi all,
Is there example code for encapsulating the key code obtained into the standard keyboard HID descriptor format and transmitting it through USB
Pushkar
