I want to controle the luminous intensity of a led with a potentiometer. The led is plugged on a analog output written by a DAC9. The input datas of the DAC9 is the output datas of the ADCINC controlled by the potentiometer on a analog input.
This project is very simple. But i can't make the led analog output follow the analog input of the potentiometer [0 - Vcc].
You'll find in attachment my project. Thank you to have a look and comments to make it work.
Thank you again.
With best regards.
Bob_Marlowe
Level 10
Level 10
Welcome in the forum, Laborie.
Led brightness control is done best using a PWM and adjusting the duty cycle. This can be done in software by a calculation using the ADC input.
By the way: Is there a reason you are using a PSoC1? I would suggest you to get a PSoC4-M Prototyping Kit which has a lot of advantages.
Bob
Bob_Marlowe
Level 10
Level 10
Bob
