I'm new to the psoc and I'm trying to get decent values from this laser distance sensor: https://www.pololu.com/product/2476
I'm trying to get the ADC to operate within the proper voltage range listed on the site (3.6 V at 10 cm to 0.6 V at 150 cm) but can't figure it out. I've tried using the -Input +/- Vref function to get that exact voltage range but something is wrong. If I use the Single Ended option and play around with the "Input Options" and "Reference" sections of the ADC I can get a little closer but at this point I'm just changing around parameters that I don't understand and hoping that I get what I need.
I need some direction, any help is much appreciated.
Thanks!
PSoC 5LP
Thanks for your help,
I figured it out. I turns out I should have kept it simple with Vssa to Vdda. Also linearized it with the proper function.
For anyone else that stumbles across this thread, the best linearization function is:
linearizedDistance = (pow(ADC_Read16(), -1.51));
Thanks again!
