LED intensity Control by using iDAC
DeAa_335316
Level 4
Level 4
First like received
 Hi
 i want to control my LED intensity by using DAC operation ... would u like to suggest me which way i can control my two parallel connected LEDs .... by  voltage or current ? .... is that possible if yes than how .. plzzz
ETRO_SSN583
Level 9
Level 9
250 likes received 100 sign-ins 5 likes given
The easy way to do this is with SSDM module or PWM, in both
cases there is an API to control density (SSDM) or compare
value (PWM) which will control average current in the LEDs.
Regards, Dana.
