I am developing one device where i need to turn on LED when signal become high and turn off LED when signal become low .during the LED blinking i have to control the LED light intensity through push up/down botton or (through capsence).
i have attached a jpg of my input signal which is for turn OFF and ON 10 times in 1 sec .
PSoC 1
Then I would consider using a comparator (simplest) to detect level
and in turn in code use that to enable a PWM. When PWM active
use its compare value to control duty cycle, hence brightness of
LED.
Set PWM period so that it is ~ 100 Hz or more to avoid flicker in LED.
Note timer would work here as well. Or SSDM module, it will result in
better EMI reduction.
Regards, Dana.
