Where is the software download kit package for CY8CKIT-050B to enable the kit to be recognized in PSoC Creator?
Greg
ispn:39617:1:0
l1:314:1:0
PSOC5LPMCU
Hi @GrCa_1363456 , @zdublin
The following page has been updated with the kit software:
https://www.infineon.com/cms/en/product/evaluation-boards/cy8ckit-050b/#
Thanks and Regards
Ekta
Hello @GrCa_1363456
There was a website transition due to which the kit software link could not be found online.
I have reported this to the web team. I have also asked them to provide the kit installer package so that I can directly attach the package on this thread.
Also, please note that the CY8CKIT-050B has the CY8C5868AXI-LP035 device. So you can select this device on the device selector and build the PSoC Creator project for this kit.
Best Regards
Ekta
I am looking for the same kit software. Is there a web link to download from now?
Thanks and Regards
Ekta
Thanks a lot for addressing this issue. But, there's something wrong with the download link at the moment.
When I click on any of three links under the Development Tools in https://www.infineon.com/cms/en/product/evaluation-boards/cy8ckit-050b/# , I get an .htm file instead of the actual file of interest.
The .htm file is a re-direct. Open it to download the .exe file that will contain the information.
Note: The "SetupOnlyPackage" is just the downloads. The "Setup" Package contains a full copy of PSoC Creator. When they switched to using .htm files, it took away visibility of the .exe file, so it's harder to determine which file is actually needed.
Greg
