Hello. My name is YS and I have a question fot Bootloader for PSoC3 or PSoC5 with Wiznet component.
I want to use bootloader function with TCP/IP.
and I found Serial to TCP/IP module(W7500S2E-R1 of Wiznet).
on PSoC side, It communication as UART,
on PC side, It communication as TCP/IP.
but, there is no example for BootLoader with this configuration but UART.
Could you give any information to do this?
Thank you.
PSoC 5LP
YS,
The Bootloader provides "hooks" for you to provide your own lower-level physical interface. Interfaces already available are UART, SPI and I2C. I believe the Wiznet device with a UART with AT command interface is possible. I don't believe a Cypress published example is available.
However, you might look to these links on this site for insights from others using Wiznet:
Bootloading PSoc 5 using Wiznet
Re: Another Ethernet Component
Len
