I'm trying to connect the ICE CUBE in the project that use the CY8C20247-24LKXI, but the error message is showed.
But, when I try to use another project, with the CY8C24894-24LTXI, the ICE CUBE connect and I can debug normaly.
Why the ICE CUBE doesn't connect when using the CY8C20247-24LKXI?
Hello @Hakenhaar ,
To debug CY8C20247-24LKXI using the CY3215-DK, we used to have footprint adapters. Unfortunately, PSoC1 is a mature family, and very few users implement new designs. Hence, our debugging tools are out of stock.
I request you to kindly consider our newest PSoC4000 family for CapSense applications.
Sampath Selvaraj
Hello @Hakenhaar ,
Kindly let me know, what target board you are using for debugging. May be that this board has some hardware issues, or is incompatible with CY8C20247-24LKXI.
Sampath Selvaraj
Hello @Hakenhaar ,
Also do kindly let me know what board you have used when debugging CY8C20247-24LKXI project.
Sampath
Hello @SampathS_11 ,
I just have this debug board CY3214 where I run the current project with the CY8C24894-24LTXI.
Now, I would like to migrate to the CY8C20247-24LKXI, just capsense application.
I would like to know if there are a debug kit to run a project with the CY8C20247-24LKXI.
Kind regards.
Christopher
Hello @Hakenhaar ,
Sampath Selvaraj
