Hello, i am a french student working with a P SOC 5LP CY8CKIT-059 (CY8C5888LTI-LP097)
My project is to build a functional timer with a 2 digit seven segment, and i need to be able to pause (or at least reset) my timer and buzz when i get sent a signal.
So, i decided to use a button to simulate the received signal while my teammates work on it.
And, so far, i've managed to make the buzzer and the seven segment work, but i can't seem to make the interruption work no matter what i do, it remains in an active (high) state.
Could you have any advice for me? i tried using NOT gates, changing the ISR state from derived to high-state and everything i could think of but it doesn't work.
Thanks for your understanding.
P.S: i use switch case for the timer, hence the cut in the middle of the code screenshots.
Timothée ZEUGIN, IUT GEII TOURS, 2022-2025
Timothee.zeugin@etu.univ-tours.fr
- interrupt
I tried with my CY8CKIT-059, and as I don't have 2 digit 7seg, I used UART instead,
but it should work for 7segs, too.
Schematic
Pins
TeraTerm log
When I push SW2 on the CY8CKIT-059, the timer stars/pauses.
main.c
#include "project.h"
#include "stdio.h"
#define STR_LEN 64
char str[STR_LEN+1] ;
volatile int sw2_flag = 0 ;
volatile uint32_t tick_count = 0 ;
volatile int one_sec_flag = 0 ;
volatile int second = 0 ;
volatile int run = 1 ;
CY_ISR(sw2_isr)
sw2_flag = 1 ;
SW2_ClearInterrupt() ;
if (run == 0) {
run = 1 ;
} else {
run = 0 ;
void print(char *str)
UART_PutString(str) ;
void cls(void)
print("\033c") ; /* reset */
CyDelay(100) ;
print("\033[2J") ; /* clear screen */
CyDelay(100) ;
/* utility functions for systick */
CY_ISR(tick_callback)
if (run) {
tick_count++ ;
if (tick_count >= 1000) {
tick_count = 0 ;
one_sec_flag = 1 ;
second++ ;
int find_empty_slot(void)
int result = -1 ;
uint32_t i ;
for (i = 0 ; i < CY_SYS_SYST_NUM_OF_CALLBACKS ; i++ ) {
if (CySysTickGetCallback(i) == NULL) {
result = i ;
break ;
return(result) ;
void init_hardware(void)
int sys_tick_slot = 0 ;
CyGlobalIntEnable; /* Enable global interrupts. */
int_sw2_ClearPending() ;
int_sw2_StartEx(sw2_isr) ;
sys_tick_slot = find_empty_slot() ;
if (sys_tick_slot < 0) {
print("Sorry No empty SysTick Slot available\n\r") ;
while(1) { } /* halting here */
} else {
CySysTickStart() ;
CySysTickSetCallback(sys_tick_slot, tick_callback) ;
UART_Start() ;
cls() ;
init_hardware() ;
snprintf(str, STR_LEN, "CY8CKIT-059 GPIO INT Test (%s %s)\n\r",__DATE__, __TIME__) ;
print(str) ;
for(;;)
if (sw2_flag) {
sw2_flag = 0 ;
if (run == 1) {
print("Timer started\n\r") ;
} else {
print("Timer paused\n\r") ;
if (one_sec_flag) {
one_sec_flag = 0 ;
snprintf(str, STR_LEN, "%d\n\r", second) ;
print(str) ;
Some additional notes,
As CyDelay() may not be accurate enough for a timer,
I used SysTick (hopefully, better)
moto
Schematic
Pins
TeraTerm log
main.c
#include "stdio.h"
#define STR_LEN 64
CY_ISR(sw2_isr)
sw2_flag = 1 ;
if (run == 0) {
run = 1 ;
} else {
run = 0 ;
void cls(void)
CyDelay(100) ;
CyDelay(100) ;
if (run) {
tick_count++ ;
tick_count = 0 ;
one_sec_flag = 1 ;
second++ ;
int result = -1 ;
uint32_t i ;
result = i ;
break ;
return(result) ;
} else {
CySysTickStart() ;
UART_Start() ;
cls() ;
init_hardware() ;
print(str) ;
for(;;)
if (sw2_flag) {
sw2_flag = 0 ;
if (run == 1) {
} else {
if (one_sec_flag) {
one_sec_flag = 0 ;
print(str) ;
moto
Hello man, thank you for the reply it's really really appreciated.
I try to understand your code but everything is so complicated it makes my whole code looks like hello world compared to it ;-;
I will try and extract whatever i can understand from it to make the interrupt work, i think the idea of using an actual interruptor in the TopDesign is perhaps what i needed.
I think i will stick to my timer using switch case because yours looks like i would need thousand of hours to even begin to understand it lol.
Hope you have a wonderful day :D.
ZEUGIN Timothée
I tried to make the code eaiser to read.
This time it contains only SW2 interrupt handling with LED1 on/off.
And main.c is less than 30 lines 😉
main.c
volatile int sw2_flag = 0 ; /* SW2 pin pushed flag, note "volatile" */
CY_ISR(sw2_isr)
SW2_ClearInterrupt() ; /* First clear interrupt flag of the pin */
sw2_flag = 1 ; /* Flag that SW2 pin was pushed */
int_sw2_ClearPending() ; /* Clear Pedings, may be not necessary */
int_sw2_StartEx(sw2_isr) ; /* Start pin interrupt with sw2_isr as the ISR */
for(;;)
if (sw2_flag) { /* SW2 was pushed */
sw2_flag = 0 ; /* First clear the interrupt flag */
if (LED1_Read() == 0) { /* LED1 is off now */
LED1_Write(1) ; /* Turn LED1 ON */
} else { /* LED1 is ON now */
LED1_Write(0) ; /* Turn LED1 OFF */
Schemaitc
pins
Hope this will serve you better.
moto
Hello, sorry for bothering you after thinking it was solved.
I am currently trying to program the switch (SW_1) like you did in the post but i don't understand why does it need to be connected to a 10k ohm resistor and to the VDD? and how does it work? because i have a 3 pin switch or a button but neither seems to work so i am very confused.
Timothée ZEUGIN
You are right, it was my bad.
I thought I was copying the information from the CY8CKIT-059 schematic.
But somehow, I ended up with some wrong values.
(Or it was the default value of the off-chip component...)
And make things worse, I left the LED as a resistor >_<
So please forget about the schematic. m(_ _)m
To make the long story short, the sample should work
without any modification and/or additional component
to the CY8CKIT-059.
moto
