While I'm trying to learn to use PSOC interrupts, I started a project to trigger an interrupt with a timer and blink an LED. Needless to say, the LED never turns on. What am I missing? Thank you for the help in advance,
#include "project.h"
Cy_ISR(Timer_Interrupt){
LED_Write(~LED_Read());
LED_ClearInterrupt();
CyGlobalIntEnable; /* Enable global interrupts. */
Timer_Interrupt_Start();
timer_clock_Start();
Timer_1_Start();
/* Place your initialization/startup code here (e.g. MyInst_Start()) */
for(;;)
/* Place your application code here. */
PSoC5 LP MCU
You need to set the interrupt generated at TC in the timer configuration. It is also advisable to set the capture mode to "none".
Happy coding
Bob
Happy coding
Bob
Those comments in the main.c are very helpful, thanks Len!
Thank you! My apologies, I could only accept Bob's reply as a solution. I very much much appreciate the effort.
