Interfacing PowerPSoC with PC for serial transfer of data
Hi all,
     In our design we have to connect the PowerPSoC (CY8CLED04D01) to PC for transferring some data. so we have to connect the UART outputs from the PSoC to an TTL5V to USB converter . We have choosen this TTL-232RG-VSW5V-WE in the link http://www.ftdichip.com/Products/Cables/USBTTLSerial.htm
    we think the above mentioned part will do good. Or is there any other better suggestions??...
Kallis
ETRO_SSN583
Level 9
Level 9
250 likes received 100 sign-ins 5 likes given
These modules also quite usable, and use standard cable such that
if cable goes bad simply get another off the shelf USB cable. Unlike
if cable wears out you have FTDI chip embedded in your other approach,
 so "special" cable has to be replaced, and its not readily available to consumer.
http://www.ftdichip.com/Products/Modules/USBRSxxx.htm
Regards, Dana.
ArvindK_86
10 sign-ins 5 sign-ins 10 solutions authored
 If you're looking for just a USB to UART controller IC, please have a look at  USB to UART Bridge Controller (CY7C64225)
ETRO_SSN583
Level 9
Level 9
If you are looking for USB to UART controller, consider PSOC 3/5.
If you want to stay with PSOC 1 this might help - http://www.cypress.com/?rID=34582
Regards, Dana.
