Interfacing Cypress CYRF6936 to microcontrollers.
        hi,
when i first started experimenting with the CYRF6936 i found there was no documentation available aimed at a hobbiest trying to interface a CYRF6936 to a generic microcontroller.
all the application notes i found only had assembly code for Cypress microcontrollers.
what i needed was a simple initialisation list showing a sample working config.
i have tried to compile such a list here:    http://sites.google.com/site/m...o-avr-microcontrollers
hope it helps someone get started.
dunk.
saiprashanthc_
        Dunk,
It is easy to interface CYRF6936 and other micro controller. You just need to check the register reference of this manual and also read the purpose of these registers and set them accordingly when you are using with other micro controllers.
The TRM for this device is :    http://www.cypress.com/?rID=14668
Hope this document serves your purpose.
Sai
Hi Sai,  the link to technical reference manual is obsolete, could you please provide a current link or attach the document to your reply!?
ingo
