Hello, Members
I am trying to filter N 24 bit data (sample 1 ~ sample N) by describing the API as follows.
Filter_Write24(Filter_Channel_A, sample1);
Filter_Write24(Filter_Channel_A, sample2);
Filter_Write24(Filter_Channel_A, sample3);
Filter_Write24(Filter_Channel_A, sampleN);
Is it possible to filter data with API description like this?
I am worried that the processing speed of the Filter can not keep up with the speed at which the value is written to the Staging Register.
Best Regards.
Bob_Marlowe
Level 10
Level 10
The filter can work up to 67MHz. Your problem will be: How to get the data in a reasonable speed. ADC works up to 1MHz. Digital data from extern can be captured at HFClk.
So can you please tell us what you exactly want to perform.
Bob
