Hi
Im an Engineering Student in need of assistance for my final Project Degree
i got an assignment involving PSOC Creator and CY8CKIT-059 5LP Prototyping Kit
I need to build a circuit that gets a sin signal from an outside generator
and the circuit in psoc creator takes that signal Vp-p and gets it stronger (Higher) or Weaker (Lower)
could someone assist me in doing so?
im new at this software and im struggling and didnt find any relevant guide/
Help
ispn:39618:1:0
l1:314:1:0
Seems like your requirement is design an amplifier . You can check out the PGA(programmable gain amplifier ) for this purpose. Kindly check the component datasheet and device code examples(File -> Code example -> search PGA). This should give you a good starting point. If you want to attenuate the signal you can check our using the CTB(Opamp) with fractional gains.
Vasanth R S
Vasanth
Vasanth R S
Vasanth
