Ekta_N
750 replies posted First like given 250 solutions authored
Hi @Ashaabanahmed
Isolation between ESP and PSoC 5LP might not be needed. You would need to check if ESP already has an isolation between WIFI part and digital part through filters.
Best Regards
Ekta
Ekta_N
Hi @Ashaabanahmed
Could you please provide more information on your application?
Why do you think an isolator is required for interfacing the esp32 module with PSOC?
Best Regards
Ekta
Hi Ekta
I am using the ADC_DelSig and analog multiplexer to form high precision 16 channel RTD Temperatures sensor scanner . so far the results so good . I want to add WIFI to my project .  of  course my concern is  the noise .
Ekta_N
Hi @Ashaabanahmed
Best Regards
Ekta
