I2C of CY8C22645
masu_1341616
Distributor - TED (Japan)
10 solutions authored 10 likes received 25 sign-ins
Hello
I use I2C I/F of CY8C22645. I have to reply quickly to device using "ACK" and understand that it need interrupt to reply with "ACK" regarding "I2CHW_1Int.asm".
I want to reply more quickly with "ACK" without software processing(include Interrupt). It is better that auto reply with only Hardware.
Do you have any solution about that?
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
Unfortunately, there is no means to "auto" ack direct from hardware. The quickest you can achieve is by acknowledging as quickly as possible in the I2C ISR.
Sampath
SampathS_11
Sampath
