JoSc_4496551
First like received
I send info thru a UART and I see that the program stays in Main. I think the timer is not running. I have attached a bundle.
thanks for any advice.
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
I saw your project.
To enable the ISR you need to call
isr_GetCounts_StartEx(isr_GetCounts_Handler) ;
So I did
(1) Changed the CY_ISR_PROTO
from
CY_ISR_PROTO(isrGetCounts);
to
CY_ISR_PROTO(isr_GetCounts_Handler);
(2) added a couple of lines
    /* Place your initialization/startup code here (e.g. MyInst_Start()) */
    Counter_1_Start();
    Counter_2_Start();
    isr_GetCounts_ClearPending() ;                               // <=====
    isr_GetCounts_StartEx(isr_GetCounts_Handler) ;   // <=====
    MeasTime_Start();    // it calls timer_init
    MeasTime_Enable();
    MeasTime_Start();
    UART_1_Start();
Then your project worked like below
Attached is your project with my modification(s).
moto
MotooTanaka
Level 9
Level 9
I saw your project.
So I did
from
to
    Counter_1_Start();
    Counter_2_Start();
    MeasTime_Enable();
    MeasTime_Start();
    UART_1_Start();
moto
Moto,
Thank you, that did the trick. I will study your changes so that I get it
right next time.
I consider this answered, but I could not find a button for that.
John
On Mon, Dec 21, 2020 at 6:47 PM Motoo Tanaka <community-manager@cypress.com>
