kep_284046
First like given
I want to ethernet in my project but i do not know where to start. Can i use MDIO interface.
HeLi_263931
Level 8
Level 8
Just look at the data sheet for the MDIO you want to use. It should explain how to access it. The you probably want to use an existing IP stack (e.g. uIP or lwip). These come with documenation how to integrate them with the actual hardware.
kep_284046
First like given
Thank you for your suggestion. How to use MDIO interface.
HeLi_263931
Level 8
Level 8
Hi, do you have any implementation or example project for what you said?
hi,
I do not have a project but if i succeed, i send my project
hotoc_2798536
Hi, OK hope you able to send and share project,
