How to implement PSOC 101: Lesson 16 and Lesson17
Y_r
50 replies posted 50 sign-ins 25 replies posted
In PSoC 101: Lesson 16,  the CySysPmSleep() API doesn't take any arguments whereas when I am trying with PSOC Creator 4.4, there is no CySysPmSleep() API, but instead a CyPmSleep() API which requires two arguments (Wakeup Time, Wakeup source).
I have gone through the inbuilt Sleep_Timer_Wakeup example which makes use of a special Sleep_Timer component (I think)... and also tried using the CyPmSaveClocks() and CyPmRestoreClocks() API's before and after calling the CyPmSleep() API --> The device goes to sleep, but doesn't wakeup.
Can anyone help understand how to bring the same functionality of Lesson 16, using a user-defined timer to the sleep project?
Similarly in Lesson 17, the deep sleep mode is achieved using the CySysPmDeepSleep() API (which is not available), and so i tried using CyPmHibernate() (similar to the PowerManagement_Hibernate example firmware), but when trying to write to the i2cbuf from the Bridge Control Panel application, the Slave is NACKing the commands --> Failure.
Please help on how to implement these examples with CY8CKIT-059 and PSoC Creator 4.4.
Yash
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Although it's not exactly the 101 is showing, I found a sample which I wrote last year.
I hope this can be some hint for you.
Schematic
Pins
Tera Term logs
1. When program started
Start up message is printed and the on board LED is blinking
2. When sw1 is pushed
The program goes into CyPmHibernate() and the LED turned off
3. When sw1 is pushed again
Program reports that it wok up. And the LED starts blinking again.
#include "project.h"
#include "stdio.h"
#define LED_ON 1u
#define LED_OFF 0u
#define STR_LEN 64
char str[STR_LEN+1] ;
void print(char *str) ;
void cls(void) ;
void splash(char *prog_name) ;
void init_hardware(void) ;
volatile int sw_flag = 0 ;
CY_ISR(sw1_isr)
    SW1_ClearInterrupt() ;
    sw_flag = 1 ;
    init_hardware() ;
    splash("5LP Repeated LowPower Test") ;
    LED_Write(LED_ON) ;
    for(;;)
        if (sw_flag) {
            print("Entering Low Power Mode ... ") ;
            CyDelay(10) ;
            CyDelayUs(20);
            CyPmSaveClocks();
            LED_Write(LED_OFF) ;
            CyPmHibernate();
            CyPmRestoreClocks(); // <= Stack in this process
            CyDelayUs(20);
            print("Woke Up!\n\r") ;
            sw_flag = 0 ;
        LED_Write(!LED_Read()) ;
        CyDelay(500) ;
    UART_Start() ;
    isr_1_ClearPending() ;
    isr_1_StartEx(sw1_isr) ;
    UART_PutString(str) ;
void cls(void)
    print("\033c") ; /* reset */
    CyDelay(20) ;
    print("\033[2J") ; /* clear screen */
    CyDelay(20) ;
    cls() ;
    if (prog_name && *prog_name) {
        print(prog_name) ;
    print(" (") ;
    print(__DATE__) ;
    print(" ") ;
    print(__TIME__) ;
    print(")\n") ;
moto
MotooTanaka
Level 9
Level 9
Schematic
Pins
Tera Term logs
#include "stdio.h"
#define LED_ON 1u
#define LED_OFF 0u
#define STR_LEN 64
void cls(void) ;
CY_ISR(sw1_isr)
    sw_flag = 1 ;
    init_hardware() ;
    LED_Write(LED_ON) ;
    for(;;)
        if (sw_flag) {
            CyDelay(10) ;
            CyDelayUs(20);
            CyPmSaveClocks();
            CyPmHibernate();
            CyDelayUs(20);
            sw_flag = 0 ;
        CyDelay(500) ;
    UART_Start() ;
void cls(void)
    CyDelay(20) ;
    CyDelay(20) ;
    cls() ;
        print(prog_name) ;
    print(" (") ;
    print(__DATE__) ;
    print(" ") ;
    print(__TIME__) ;
    print(")\n") ;
moto
EDITED!!!
Hello Tanaka-san,
Thank you for sharing the project. Works great!!!
I was wondering on how we can use CyPmSleep() API and implement the normal sleep functionality.
Can you please help with this?
Also, from the program shared above, what would need to be changed in order to use the EZI2C (Similar to Lesson 17) instead of the switch?
-- I understand that the Deep Sleep function is not supported by PSOC 5LP (System Reference Guide, Pg. 49, Table.1).
Yash
MotooTanaka
Level 9
Level 9
I have just posted a sample for Lesson 16.
https://community.cypress.com/t5/Code-Examples/PSoC-5LP-sample-for-PSOC101-Lessong-16-counter-part/m...
I'm going to work on Lesson 17, but I don't know when it's going to be available...
moto
Hello Tanaka-san,
I downloaded the project attached with the code example and tried to run it.
The device goes to sleep, but there's no wake up text on UART even after waiting for a minute.
The UART log:
Can you think of what can be the issue causing this?
Yash
MotooTanaka
Level 9
Level 9
It was my bad, seeing the table, I realized that we can not wake up using timer interrupt.
So I deleted my code example thread.
We may be able to use CTW, which I have been trying, but not successful yet.
I will add reply if I will be able to find a method.
But for the time being please survive with the lesson 17 example 😉
moto
MotooTanaka
Level 9
Level 9
From the PSoC Creator's Code Example, I found
"SleepTimer_Interrupt_Sleep", which is using CTW.
And I modified it to use CY8CKIT-059.
moto
MotooTanaka
Level 9
Level 9
For the lesson 17, as you found, we don't have "Deep Sleep" and we can not wake up from Hibernate using I2C as the table below suggests.
So I modified the lesson 17 to use "CyPmSleep()"
1. Schematic
2. I2C (EZI2C) Config
Note: I2C1 is needed to be used!
3. Pins
main.c
#include "stdio.h"
#define LED_ON 1u
#define LED_OFF 0u
void blink_led(int num)
    int i ;
    for (i = 0 ; i < num ; i++ ) {
        LED_Write(LED_ON) ;
        CyDelay(100) ;
        CyDelay(100) ;
    uint8_t i2cbuf[1] ;
    EZI2C_Start() ;
    EZI2C_SetBuffer1(1, 1, i2cbuf) ;
    for(;;)
        blink_led(4) ;
        EZI2C_Sleep() ;
        CyPmSaveClocks();
//        CyPmHibernate();
        CyPmSleep(PM_SLEEP_TIME_NONE, PM_SLEEP_SRC_I2C) ;
        EZI2C_Wakeup() ;
        CyDelay( 5000 ) ;
Can we call it a week?
moto
Tanaka-san,
Thanks for all your help!!!🙌
You really are a life-saver and very knowledgeable.
I just had a small doubt as to why we can't use I2C0 and only need to use I2C1 for Lesson17?
Yash
MotooTanaka
Level 9
Level 9
In the TRM, there is the following table.
According to the table, P12[0:1] are for I2C1 (as their dedicated I/Os).
Although I2C0 may be able to use these pins, the signals need to go through
other internal switch(es) and they may not be working when the device is in low power mode.
moto
