yaga_3967241
50 sign-ins 25 sign-ins 10 replies posted
For PSoC 5LP I2C component, how to get error status of I2C_MasterReadByte() API? The function returns the byte read from slave. However, if something goes wrong, how can I get the error status?
Winston
Krupashankar
500 replies posted 50 likes received 25 likes received
Hi @yaga_3967241 ,
API - I2C_MasterStatus( )
Description: This function returns the master’s communication status.
Parameters: None
Return Value: Current status of the I2C master. Each constant is a bit field value. The value returned
may have multiple bits set to indicate the status of the transfer along with the generation of
error conditions.
Please refer to this datasheet for detailed explanation
Component - I2C V3.50 Datasheet.pdf
You can also refer to the code example
https://www.cypress.com/?rid=105713
Krupashankar
Krupashankar
Hi @yaga_3967241 ,
Parameters: None
error conditions.
Krupashankar
