Hello Everyone,
I want to increase no of samples and for that i want to do oversampling. Could any body guide me how i can do this?
I am using SAR ADC in PSOC 5 LP.
Looking forward for your reply.
Best Regards
Bob_Marlowe
Level 10
Level 10
When you want to digitize a frequency f the minimum sample rate is 2f (Nyquist). So anything higher than Nyquist is usually called "oversampling". A factor of 5 to 10 (10f to 20f) will be sufficient. As you can see a low-pass filter with cutoff at f + will improve the digitization.
The fewer channels you have got, the more samples per second you can take.
Bob
Bob_Marlowe
Level 10
Level 10
Bob
