I want to multiply two signals using a mixer. But i want to give clock a sign signal. I tried to do that but it shows an error signal attached with this message.
Please guide me how i can do this.
Looking forward for your reply
Best Regards
Awais
Bob_Marlowe
Level 10
Level 10
When you take a look into the mixer's datasheet, Input/Output Connections, you will see that LO is a digital signal and not an analog one. On page 2 is a picture showing how an Up Mixer works.
So getting a true analog product of the two signals will not be possible this way.
Bob
I want to Multiply my analog sine signal with clock, which should also be sine signal.
Bob_Marlowe
Level 10
Level 10
Bob
Yes Bob you are right. But I want to Multiply two signals. 1st is my message signal which is in analog form and the 2nd one should also be in analog form with same phase. How i can do this?
Is it really possible?
Looking forward for your reply.
Best Regards
Awais
ETRO_SSN583
Level 9
Level 9
The mixer is not a Gilbert Cell mixer as in full analog, look at its functional
description in datasheet.
To use sine as LO use a comparator as follows (attached).
Regards, Dana.
ETRO_SSN583
Level 9
Level 9
If you need true analog then consider SAR >> DFB Filter >> VDAC as solution.
The Mult occurs in code or DFB -
http://www.cypress.com/?rID=60720     DFB Assembler, MAC Topics
http://www.cypress.com/?app=forum&id=2492&rID=76907     DFB Assembler
https://www.youtube.com/watch?v=2UC4gCohrk8      DFB Video Part I
https://www.youtube.com/watch?v=6tr_CNWIA8M     DFB Video Part II
https://www.youtube.com/watch?v=nIa4X7gES3k     DFB Video Part III
This all depends on analog BW needed and dynamic range and....
Regards, Dana.
Thank you for your valuable reply.
Now, What i concluded is, i can only implement lock in amplification (Multiplication of two signals having same phase) in PSOC through digital signals?
This means i have to convert my input signals into digital form and then performs filtering and amplification stuff?
Am i correct?
Awais
ETRO_SSN583
Level 9
Level 9
One approach done in PSOC 1 -
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CCYQFjABahUKEwi_...
Regards, Dana.
Thankyou so much for this.
I am not sure how i can control the phase through this approach.
Do you have any idea?
Best Regards
Awais
