Sep 11, 2022
09:08 PM
Sep 11, 2022
09:08 PM
Sep 12, 2022
12:11 AM
Sep 12, 2022
12:11 AM
Hi @shuvra1
As working electrode, Reference Electrode and counter Electrode is connected to analog devices(opamp and TIA) so connect these electrodes to analog pins of PSoC 5lp. Like CE is output of opamp so assign these pin to opamp Vout, RE has to assign to Vminus of opamp. Similarly you can do for all the pins. For more information on that you can go through below links:-
Thank You
Best Regards
Sahil Kumar
Sep 12, 2022
12:12 AM
Sep 12, 2022
12:12 AM
What about WE? Let me know.
Sep 12, 2022
12:15 AM
Sep 12, 2022
12:15 AM
Hi @shuvra1,
WE is also connected to the negative terminal of TIA(basically it's an opamp) so connected this pin to the Vminus of the opamp.
Thank you
Sahil Kumar
Sep 12, 2022
12:19 AM
Sep 12, 2022
12:19 AM
