I have a CY8CKIT-059 kit, at the moment, I would like to be able to program the PSoC either with the Pi GPIO using http://wiringpi.com/ or preferably over the USB.
I found the following Land Boards solution, it compiled, but did not work me:
https://github.com/land-boards/RPPSOC/tree/master/HSSP
I am willing to pay someone for a solution; I am surprised that there is no Linux supportted programmer cli for PSoC 1,3 and 5 since linux seems to be the embedded defacto.
PSOC5 LP MCU
Hello @jairusmartin
You can refer to the following Appnote: PSoC® 3 and PSoC 5LP Programming Using an External Microcontroller (HSSP)
This application note explains how to implement a host programmer to program a PSoC 3 or PSoC 5LP device.
Since you are using a programmer other than PSoC 5LP you will need to recalculate the different parameters mentioned in the Appnote.
Best Regards
Ekta
