How to Export a variable in PSoC Creator 3.1
Hello everyone,
I don't know if I'm in the right forum but I have a question about the PSoC Creator 3.1.
I would like to know if it is possible to export a certain variable to be used in Matlab for some calculations.
Thanks for your time 🙂
 Carlos Loura
cadi_1014291
Level 6
Level 6
25 likes received 10 likes received 10 likes given
From what i understand you want to send a variable of your program to Matlab? If so, maybe send it via UART is one of the most easiest ways, here's a video about sending a voltage reading of the ADC of the Pioneer Kit to plot it on a graph on Matlab, it's done via UART,  here it is: https://www.youtube.com/watch?v=z6O9xD-SUYU
It's on spanish, but it can help, it's easily portable to a PSoC5
Hope it help you
Carlos
Hello Carlos, thank you for your reply!
I understand what you mean, and I can understand written Spanish so I took a look at the example you gave me.
Problem is, I am looking for something simpler. When I programmed ARM processors using Code Composer Studios I was able to right click a variable during the debug session and save that variable into a text file (that I afterwards imported to Matlab and ran some calculations on it). I wanted to know if it is possible to do something like this in PSoC creator 3.1.
Thank you for your time,
 Carlos
Bob_Marlowe
Level 10
Level 10
Inspecting and setting a variable is possible in creator, but storing its value in a log-file is not.
Bob
