How to Connect SDA and SCL to multiple PSoC pins
AmCi_3754291
Hey,
I have a board that has SCL connections to pins 49 and 60 and SDA connections to pins 53 and 61. I am trying to connect all 4 of these pins to the same I2C Master block. Is this possible? If so How do I do it?
I tried the design in the image, but that complains that the lines are driven more than once
Amilcar
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Assuming that you are using LOGO for monitoring (output),
I could generate application with following schematic.
Note: The triangle is "Digital > Logic > Bufoe" and LOGO pins are "Bidirectional, Strong Drive"
Note2: I have not tested if it works or not.
moto
MotooTanaka
Level 9
Level 9
moto
