I have trouble programming the CY8C29666-24PVXI. I am using the PSoC Programmer 3.29.0 and can't select the CY8C2xxxx Device Family. There is no option there. Do I have the right software to program the microcontroller, or do I need to install something else?
PSoC1 MCU
Connect a MiniProg or MiniProg3 and start PSoC Programmer. Kindly put the Programmer in "ISSP" mode in the "Programmer Characteristics".
Then, select disconnect the MiniProg, from the "Port Selection" box on the top right. This will enable "Device Family" and "Device". Select "29x66" in the "Device Family" and then "CY8C29666-24PVXI" in the "Device" selector.
Sampath Selvaraj
Sampath Selvaraj
