I have a Standard I2C Slave block functioning, but need to add Capsense and Capsense Tuner. Tuner requires an EZI2C Block, but I get a placement error when trying to compile.
I really do not want to rewrite my functioning I2C Slave code to use the EZI2C block.
Is the only way to get multiple I2C ports with the EZI2C primary and secondary addressing?
Thanks!
PSoC 1
- multiple i2c
We face similar situation often in CapSense application design, if cannot add one more EzI2C block in project and assign another pair of pins for it, you'd better create a new project specially used for CapSesne tuning and then import the CapSense tuning data into current project.
