magic_3776931
I tried to add the source files and the header files drag and drop them in the explorer window.
I tried also to drag and drop the library folder in the project folder but I don't find it in the explorer window.
Can someone help me? What is the right way to add an external library in a psoc creator project?
GeonaP_26
250 solutions authored 100 solutions authored 50 solutions authored
Right-click on a project in the Workspace Explorer and select Add > Existing Item. You can also select Existing Item from the Project menu.
GeonaP_26
magic_3776931
thank you, now i have understand how to do but I still have a problem with the path of include files..
I could solve it adding each path, but I'm finding out an easy solution because I have several files to add.
Do You know an easy way?
You can specify location of additional directories to the compiler's include path; Project > Build Settings > ARM GCC > Compiler > Additional Include Libraries.
