Hi All,
I made a PSOC project that contains components from PSOC (Mixer, Amp, SAR ADC, DAC, PWM, Shift register and SPI interface). Some output components are also used (INAmp, Buffer and some filter stuff).
I let the PSOC to route freely and then, I tried to change the pins and it works fine.
Now, when I built the project. It builts successfully (Can see attached Pic).
I just wanted to know that, it is enough or, is there any other way of confirming it?
Looking forward to your suggestions.
maknight
PSoC 5LP
If there will be any issue in routing the PSoC Creator will report it in form of Warnings or Notes or even Errors in "Notice List" section.
If there is nothing mentioned in Notice List,then you can be assured.
