Hi - I'm using a WaveDAC8 in my PSoC 5 LP design. I set the WaveDAC8 clock to 1 MHz and I get a timing violation warning:
Warning: sta.M0019: NORAD_controller_1_timing.html: Warning-1367: Hold time violation found in a path from clock ( CyBUS_CLK ) to clock ( \WaveDAC8_1:Wave1_DMA\/termout ). (File=B:\OpticalDelayLine2018\PSoC_projects\Workspace_NORAD\optical_switch_controller_1\NORAD_controller_1.cydsn\NORAD_controller_1_timing.html)
I tried to lower the WaveDAC8 clock to 500 kHz and got the same warning...
Any suggestions?
thanks much - Paul
Paul,
If permitted, please upload a project: (1). Build->Clean; (2) File->Create workspace bundle->Minimal; (3) to reduce file size delete "Generated_source" folder in newly created archive.
I believe that the issue arises due to wc1/wc2 outputs. These are direct output from DMA nrq output, which is not in sync with BUS_CLK. Try to add a Sync component to it, synchronized to the BUS_CLK.
/odissey1
Paul,
/odissey1
Thanks for the SYNC suggestion on the WC output. That did the trick, no timing warnings now. Thanks very much.
Paul
