The problem in main.c is due to the fact that when you tried to reuse the code for DMA transfer, the pointer being used corresponds to ADC . Which is not present in the design. You have to modify the code, such that either pointer corresponding to VDAC is used.
VSRS
She is trying to use a UART for the data instead of a ADC. She has no said what values of ASCII she is applying to the UART.
VSRS
