PaCo_972561
5 questions asked 5 replies posted Welcome!
It complains failed to route net "AmuxNose:AMux_1_CYAMUXSIDE_A".  I disabled all other components and it still can't route the AMUX.  It's now essentially the same as the example thermistor calculator code example.
Also: Is there a way to create a support case?
thanks - Paul
Vasanth
Moderator 250 sign-ins 500 solutions authored First question asked
Hello Paul,
Cypress Developer Community is our primary platform for support now. Could you please let me know the exact part number you are using ? Also let me know the modifications you have done to the example code ? Have you changed any pins in the design and locked them to some other ?
Vasanth
