abtac_4079016
Hi, I am a new user for PSOC 5LP, I am wondering if there is any advise to start over with, as what is the best kit for CY8C5287AXI-LP095 and STEP MOTOR CY8CKIT037.
If I need help in the schematic and programming, can I find help to review my work?
Vasanth
Hello Abdullah,
The CY8CKIT-037 kit has been specifically designed to mate with our popular PSoC 4 CY8CKIT-042 pioneer kit. To get PSoC 4 CY8CKIT-042 kit, visit  https://www.cypress.com/CY8CKIT-042  .
To start using CY8CKIT-037 kit please use the following link  https://www.cypress.com/documentation/development-kitsboards/cy8ckit-037-psoc-4-motor-control-evalua... . It has example codes, schematics and user guide for you to start with your project.
Vasanth
Vasanth
Hello Abdullah,
Vasanth
Thanks a lot for consideration my request.
I have a question regarding CY8C5868AXI-LP035, this is surface mount
chip, which board or socket or .. fit to connect it to PC by USB or
Bluetooth?
Abdullah M.
On Thu, Mar 14, 2019 at 11:24 AM VasanthR_91 <community-manager@cypress.com>
Hi Abdullah,
If you are looking for a development kit with CY8C5868AXI-LP035 device please check CY8CKIT-050 PSoC® 5LP Development Kit. This can be connected to PC over USB and programmed.
https://www.cypress.com/documentation/development-kitsboards/cy8ckit-050-psoc-5lp-development-kit
Kindly go through the Kit userguide in the related documents to understand more about the kit. But this is not designed to be used with CY8CKIT-037 kit.
Vasanth
Dear Vasanth
I have question regarding the role of cypress after choosing the proper
chip and built it up and program it using the specific kit, what next?
how can I get the chip that has been customized, as the chip surface mount
on the kit?
I hope my question is clear.
Abdullah M.
On Thu, Mar 14, 2019 at 3:07 PM VasanthR_91 <community-manager@cypress.com>
Hello Abdullah,
I am not sure whether I understood your request completely. If you are developing your product you can use any of our development kit to start with the design. Once the design is finished you have to make your own board for the application. There is no customization on the chips you are receiving. You can program the chip with the developed application for the PSoC part to behave the way you expect it to work.
Vasanth
Hi Vasanth,
Thanks for your reply,
Yes, you got my question,
does the developing kit has socket to load different chips with same
numbers of pins for example (100), which means the chip attaches to the
holder and reusable for other same number of pins chips, because as I have
seen from the cypress video the chip looks surface mount to the board of
the kit, I hope I am wrong , this is why I am asking such question and let
me grinding halt with my project.
do you think that Cypress has services for its customers to build up and
implement the entire project after preparing each chip based on our
project, instead of sending project to other company for such purpose?
Does Cypress has representative in Ottawa-Canada?
Abdullah M.
On Tue, Mar 26, 2019 at 2:14 AM VasanthR_91 <community-manager@cypress.com>
Hello Abdullah M,
Unfortunately all of them are surface mount. We do not have a generic holder solution. You can always develop your project using a kit which has the same family of device and extend it to your actual design. Switching between devices and projects are easy when you are using PSoC Creator.
Now for design support, you can make use of our design partner program. These partners have demonstrated competence in Cypress products ensuring that only partners with the best skill sets are available to our customers. https://www.cypress.com/design-partner-program/partners
Vasanth
