I'm trying to update the software for a firmware chipset, and I'm having trouble understanding how variables are passed between C and assembly. When I try to compile, I get these errors:
https://gist.github.com/anonymous/d79f8f9734865a3ec1fe
These variables are defined in global.h here:
https://gist.github.com/anonymous/d81de7895838eaa41361
Also, lib/timer8_1int.asm is pretty short, so here it is:
https://gist.github.com/anonymous/848875129e7cf16e110f
Thank you for your time.
I'm using PSoC Designer 5.4 to write and compile this code, if that helps anyone.
PSoC 5LP
Maybe its better to post thios question in the PSoC1 forums. In the PSoC5 world assembler is rarely used...
You are here in the PSoC5 forum, Designer 5.4 is for PSoC1 only.
In Designer -> help - > Documentation you find a C- manual and an Assembler manual. There you find the informations on how to interface both worlds.
Bob
Thank you all for the replies. I will be cross-posting this to the PSoC1 forums.
