Mar 21, 2019
10:29 AM
Mar 21, 2019
10:29 AM
I have implemented the proposed method on the AN2283 site and fail to measure the frequency of a perfect 2 kHz sinus.
I checked out the external variable: bDataAvailable, wSaveCountNum, cSaveOverFlow , wSaveTickNum and they have the value 0x0000 or 0xFFFF.
Here are some prints and program code attached.
I appreciate your help
Andrei
Mar 21, 2019
10:41 AM
Mar 21, 2019
10:41 AM
Hi Andrei,
Is your input signal digital or analog?
-Kenny
Mar 21, 2019
02:48 PM
Mar 21, 2019
02:48 PM
Hi Kenny,
The input signal is analog.
Thanks!
Mar 22, 2019
02:20 AM
Mar 22, 2019
02:20 AM
Yes I think that's the issue.
You may have to pass your signal through a comparator first, to make it a square wave, then use that as the input-signal.
Mar 22, 2019
05:12 AM
Mar 22, 2019
05:12 AM
I did this and still 0 remains.
Apr 03, 2019
11:56 PM
Apr 03, 2019
11:56 PM
Can you check if you can see the signal at the output of the comparator?
