Hello, I would like the pSoc-5 to get interrupt when using USBFS-UART, each time a byte is received. How to do that? Best regards, Guez Segev, BSc. Software engineer CI Semi - A division of CI Systems Migdal HaEmek 10551, Israel Tel: +972-4-644-8873
How to do that?
Guez Segev, BSc.
Software engineer
AnkitaS_51
There are ISR for each endpoints inside the file USBUART_episr.c. You can add your code in the OUT EP. When host is sending data to device OUT EP ISR will be triggered.
AnkitaS_51
